First post, by digitaldoofus
- Member
Disney Sound Source...requires LP1? Or can you use LP2?
Need to know for possible use with a Tandy 1000 TL/2, which has an "edge connector" port on LP1, so I am forced to consider installing a true parallel port on LP2. If I do, will a Disney Sound Source stubbornly try to suck a signal from LP1, or can it be rerouted to draw sound signal from LP2?
Once you go retro, you'll never go back...
