ViBRA 16XV VLSI
First post, by senrew
My girlfriend has this old PII machine lying around. I pulled it out, found the manual for it, and noticed it has a ViBRA 16XV VLSI onboard. The manual spouts on every few pages about onboard Creative 3D sound.
I've never heard of this chipset. I did some googling, found a bunch of forum posts all over the place but still don't quite know where this slots into the great scheme of things.
From what I can tell it's a SB16-series chipset, cost reduced and used for integrated sound on certain stand alone boards and mobos.
Can someone shed some light on the chip and where it stands?
The mobo in question is a Create LXe-AT. The manual for it can be found here: http://www.motherboards.org/files/manuals/150/pii_0140.pdf
Reply 2 of 6, by Old Thrashbarg
Yep, it's a cut-down, integrated version of the SB16. Generally speaking, they have a bit cleaner sound than the older SB16s, but most versions lack things like the OPL3, so they're not as good for games as a 'real' SB16. I don't know much about the XV version specifically, but I'd say it falls in the lower-end of the spectrum of sound cards... generally usable, but not great and not particularly desirable.
Reply 3 of 6, by senrew
Yeah, that was one of the pages I'd found on my first google run. Lots of information there. Now I just need to figure out how to find out exactly which version I have in here so I can figure out whether I want to use it or find another isa card.
Reply 4 of 6, by Old Thrashbarg
Well, looking at specs and discussions will only do so much... I'd recommend you just try it, and see what you personally think of it... and that includes the sound quality, the setup process, everything. Sound cards tend to be pretty subjective anyway. If it turns out you're dissatisfied with some aspect of it, you can always go back and add a card later on.
Reply 5 of 6, by ux-3
I just got an CT2980 with the (Vibra) CT2502-SDQ chip. The card was not noisy, sounded decent but had the Hexen bug. DSP is 4.13. No OPL3 visible.
According to link above, best S/N ratio of the SB16 ilk. Too bad.
Retro PC warning: The things you own end up owning you.
Reply 6 of 6, by nights
Never had a problem even with half assed sound blaster clones they always worked perfectly even if ALS-100s need -5v lines and are picky even on the power supplies! (this is linux)
but who still uses dos as general purpose os on 386+ with enough ram anyway
