First post, by qbert2001
qbert2001
Offline
I'm not all that familiar with configuring DOSBox. Can someone please tell me if it's possible to reconfigure certain keys? I run the ADAMem (Coleco ADAM) emulator in DOSBox with a front end called Virtual ADAM.
Unfortuantely when it's running, the same keypress (CTL-F9) that is used to allow you to swap disks and make other configuration changes when the emulator is active is also the same keypress that kicks you out of DOSBox.
Is it possible to change or disable DOSBox's use of CTL-F9?
Thanks
