First post, by dangjh
So i have Goblins quest 3, and im trying to install it/play it using dosbox on Vista and ive run into an issue.
I have the cd version, so i open up Dosbox, mount the CD drive as E using
mount E E:\ -type CD-ROM
Then i change to E, then try to run the install
It starts to work then it pops up with what looks like a good ol dos instalation screen, but says, "This application requires a CD rom. In case of Difficulty, refer to the manual"
I am running it FROM the CD though.... I even tried copying the entire disc to a folder on my C drive then mounted that folder, and it still didn't work...
If anyone can help me, they are my hero.
Thanks!
Reply 2 of 5, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by Teppic
Type "mount d e:\ -t cdrom"
You can also run the CD from the hard drive, by converting it to ISO/BIN+CUE/IMG. Then you type the following:
"imgmount d "path to the image file" -t cdrom"
Reply 4 of 5, by dangjh
Man, you guys are awesome, Thanks for the ultra quick and accurate responses.
Everything is working like champ now!!
Reply 5 of 5, by IIGS_User
I think I see the difference now. 😅
Klimawandel.
