First post, by DosFreak
* Must have at least IE5 installed!
1. Download and Install Qemu Manager.
2. Execute Qemu Manager.
If you receive an error about wininet.dll then you do not have IE5+ installed.
3. Open Qemu.exe with the Hexedit program.
4. Replace "freeaddrinfo", "getaddrinfo", and "getnameinfo" with "gethostname".
5. Start Qemu Manager!
6. When you create a VM in the VM options change "Main Display" to "QEMU Windows", otherwise your VM will not load.
Make your games work offline
