Faery Tale Adventure 2
First post, by Nytegard
I installed the windows version of the game, and it crashes every time I try to use a book.
They include a DOS version, but I can't seem to install it, even with VDMS sound. It doesn't copy anything over.
Using Windows XP on an AMD 2000XP & Radeon 9800.
Reply 1 of 1, by Nicht Sehr Gut
Originally posted by Nytegard I installed the windows version of the game, and it crashes every time I try to use a book.
I have the CD somewhere, but it may be a while before I can test it.
Try installing it without using VDMSound, sometimes running VDMSound on the installer can produce "unpredictable" results. You can always run the sound setup at a later time.
Also, be aware that the DOS version requires DOS VESA support. It seems to work fine with a GF3, not sure about the Radeon 9800.
