First post, by bergqvistjl
Hi guys, i'm playing monkey island 1 or 2 (their original floppy versions, copy protection and all 😎) in DOS 6.22 Yet i cant seem to get any sound out of them. i've applied all the updates i could find off of the lucasarts website, yet no matter which parameter i set for the sound device (Im using an AWE 64 Gold ISA card) when i load monkey island, i get zero sound. Its strange because other DOS games ive tried work fine with the soundcard. nothing wierd with the settings on my card either, Port 220, IRQ 5 and DMA 1. Anybody got any ideas? Ive got the sound working i n windows for workgroups 3.11 (no special tricks needed there), and i tried playing the games from within that incase that made a difference but they dont run. Its wierd, on my win98 machine which has the same card, it plays absolutley fine.
Reply 1 of 16, by Amigaz
Is your AWE card initialized as it should in the DOS enviroment?
Reply 3 of 16, by bergqvistjl
Well i assume it is. Every other DOS game i've tried works with it, windows 3.11 also works with it using the drivers that came provided with 3.11. and its a P3 650mhz, and ive applied the 486 patch for the games.
Reply 4 of 16, by Davros
try a slowdown util
or do you have win 9x or later on that pc try scummvm
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
Works fine in dosbox, too.
Reply 6 of 16, by Davros
wouldnt a P3 650mhz be too slow for dosbox ?
Reply 7 of 16, by wd
Rank DOSBox Author
DOSBox Author
I suppose you can upgrade that pc.
Reply 8 of 16, by Amigaz
The Lucastart adventure games aren't very speed sensitive...
It might be worth checking that the ISA speed is 8mhz in the BIOS
btw. which games have working Adlib music on your machine with the AWE 64 gold?
Reply 9 of 16, by wd
Rank DOSBox Author
DOSBox Author
iirc. at least monkey1 is speed sensitive (adlib related? dunno)
Reply 10 of 16, by Amigaz
Really? never noticed it on my PIII 1ghz rambus rig
Might be related to what hardware you have...
Reply 11 of 16, by bergqvistjl
You were right about the initialisation Amigaz, I downloaded ctcm and the aweutil (plus mixerset, etc.) and got it working. Although I must say the mt-32 soundfont isn't all its cracked up to be. is it possible to connect a real mt-32 (if i ever get one) to my AWE64 Gold (I presume thats the only way i can do it since thats my only sound card)? (Btw i'm using REAL DOS)
Reply 12 of 16, by Amigaz
Glad it worked 😀
The MT32 stuff that the AWE cards do sound very cheesy
Not sure if MI 1 & 2 uses intelligent modo so the Roland music might sound wrong if you hook up an MT32 with a joyport to midi adapter
Reply 13 of 16, by robertmo
intelligent mode is about working/not working, nothing to do with wrong sound
and i don't think any lucas arts game requires intelligent mode to work
Reply 14 of 16, by collector
And it will never be. While it might come close to some of the sounds of the MT-32, it will never be able deal with the SysEx messages that a real MT-32 or even Munt can process.
Reply 15 of 16, by bergqvistjl
hmmm, so hypothetically how would i connect a real mt-32 to my pc. switch to an LAPC-I card instead?
Reply 16 of 16, by robertmo
you can have both cards, or just connect mt32 to mpu401/gameport
but the easiest way would be to use dosbox with buildin mt32/lapc emulator
