First post, by vanatom
Hey guys
Just a quick silly question. I'm using DOSBox to run an old midi sequencer and I'm using the hercules machine emulation. I love running it in amber but it's really annoying to have to cycle through the colors with F11 every time I start DOSBox.
Is there any way to set DOSBox to automatically change the color to amber at startup?
I'm using an intel Mac Pro 2 x 2.66GHz Dual-Core Intel Xeon, 1GB 667 DDR2 RAM running OS X 10.4.11 (Tiger).
Thanks a bunch!
JvA
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you would have to change the sourcecode and recompile.
Water flows down the stream
Reply 2 of 4, by vanatom
awwwww... can I put in a feature request for the next build? 😁
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
maybe if it is a popular request. Currently I don't want to waste configfile space for it. nor make other options more complicated.
Reply 4 of 4, by vanatom
fair enough, I'll have a look thru the source code and see if I can't work it out.
Thanks for your help and quick replies!
