capslock and numlock
First post, by Shadbox
Hello everyone
I searched the entire forum but didn't found any solution.
I need DOSBox to start with Caps and Numlock turned on because I use a soft that works with code articles in caps.
It's that possibly?
Thanks in advance!!
Reply 1 of 3, by Vince.Bloodworks
Hey Shadbox
I though about the same thing and while I did not found a solution I just written a little program to do this! Download the zip, decompress it in your folder where dosbox stores the data and add "LOCKS.EXE" in your Dosbox.conf to load it on startup. Numlock and Capslock should be turned on when just started Dosbox.
Hope this will help you.
Greedings
Vince
PS: Please write me a mail to Punker_1992@live.de if it works or not.
Thank you 😁
Reply 2 of 3, by robertmo
D-Fend Reloaded has got what you want in its keyboard options. I wonder how it does it.
Reply 3 of 3, by Harry4850
IT works!!
put 'locks.exe' in my DOS path, and it is the last program to execute in my Autoexec file in DOSBOX 0.74.javascript:emoticon('😊');
Pjavascript:emoticon(':blah:'); Putting in the program director does ;not help/work like another writer did.
