First post, by joebro
I have read the manual and Wiki but is does not go into great detail about setting up a directory for captures. The Wiki says that a capture path is created automatically with the newer versions of DOSBox. Anyway, I hit Crtl+F5 during a game (Quest for Glory I - EGA) and nothing seems to happen. I check the capture folder and nothing is in it except the text file describing the capture key commands. What am I doing wrong? Maybe someone could explain how they have successfully obtained captures while playing a game and what (if anything) they have edited in the config file.
Any help is appreciated. Thanks.
Reply 1 of 6, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
Reply 4 of 6, by joebro
DOSBox version: is 0.74; downloaded from DOSBox.com; the executable is located at C:\Program Files\DOSBox\DOSBox.exe
Operating System: MS Windows Vista Home Premium, 32-bit
PC Specs: Intel Core 2 Duo, 2.00GHz; 2.00 GB RAM; GeForce 8400M GT w/ 256MB video mem
"DOSBox Status Window":
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\Users\User1\AppData\Local\DO
SBox\dosbox-0.74.conf
MIDI:Opened device:win32
DOSBox config files:
Global config file (dosbox-0.74.conf) - attached
Quest for Glory I - EGA config (dosbox.conf) - attached
Path of "capture" folder:
C:\Users\User1\AppData\Local\DOSBox\capture
Thanks for the help.
    dosbox.conf
    388 Bytes
    155 downloads
    dosbox-0.74.conf
    10.74 KiB
    142 downloads
Reply 6 of 6, by joebro
Thanks, that fixed it. I hit Ctrl+F5 now and a PNG file is saved in the capture folder. I used a DOSBox installer to setup my QFG Anthology games and the config file it automatically produced had the quotation marks around the path name.
Anyway, good to go. Thanks.
