First post, by coolhaken
Dear all:
I have an old application named as "Magic Key".
A CGA mode emulator and screen capture software of Hercules card.
It works well in DOSBox 0.70 but 0.72~0.74.
Look the captured images below .
DOSBox 0.70
But in DOSBox 0.72~0.74
Reply 2 of 3, by coolhaken
DosFreak wrote:
Did you try "machine=hercules" in DOSBox.conf?
Yes, I did.
In my opinion, this is not my problem. This post just shows that
the compatiblity of DOSBox running in hercules mode between 0.70
and 0.72~0.74.
Maybe there are bugs in sub-routine(s) about hercules mode.
My configuration (DOSBox 0.74) :
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
[dosbox]
language=
machine=hercules
captures=capture
memsize=1
[render]
frameskip=0
aspect=true
scaler=none
[cpu]
core=auto
cputype=auto
cycles=fixed 281
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\CP\PATCHES
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
mount c d:\8086\
path=c:\dos;c:\tools;z:\;
ver set 6 22
mode con: rate=20 delay=2
c:
Reply 3 of 3, by nikiniki
I have simcga and setcga to make CGA games to run under hercules graphics but magic key looks awesome. Where can I find it?
