King Quest VII on dosbox
First post, by Zangdaarr
Hi everyone, i'm trying to get this great game running on dosbox which is supported since version 0.63
I installed a copy of windows 3.1 into my dosbox system and I installed the game.
The game installs well, all tests are passed with succes.
However when I launch the game, I have no music at all ! But i get sounds. Playing that game without music is a pain.
Could anyone help me playing KQVII correctly with dosbox ?
Thanks
Reply 3 of 14, by Zangdaarr
I remember i did it, and the Sierra music test leads to music very well
Unfortunatly, the installer do not work cos my cd is version 1.65 😒
Reply 4 of 14, by collector
Sorry, the installer only works for 1.4, 1.151 and 2 and up. It is version specific because it uses a binary level patch that I have to have a copy of any given version to make the patch. It updates the game to version 2.00b, which address most of the bugs in the game and includes a DOS interpreter that can be played directly in DOSBox. I only have a copy of versions 1.4, 1.51, 2 and 2.00b. I could make it work for 1.65 if I had a copy of it, but I do not.
Reply 5 of 14, by pariah
How do I verify which version of the game I have?
I'm having the exact same problem as the OP, and I've been trying to use VDMSound to compensate, but it doesn't seem to want to work.
Reply 7 of 14, by pariah
I used the installer earlier, but I didn't see anywhere that it clearly identified the version I have.
I checked the INF file I have:
[Ident]
Version=151
ProductID=83308
Does this mean I have ver. 1.51? If so, this should work right?
Reply 8 of 14, by pariah
I don't mean to bump, but I'd really appreciate some correspondence on this issue.
I essentially walked away from it a couple months ago, and now I'm back to it again.
I tried the steps again with no luck. But I'm still not sure if its because of the version I have or not. Could someone confirm that the line of code of I quoted confirms my version?
Reply 11 of 14, by hstigz
I have tried pretty much everything to install King's Quest VII, can anyone help me please?
Reply 12 of 14, by Jorpho
That's not particularly informative. What happens when you try the installer discussed above?
Reply 13 of 14, by hstigz
A message still appears saying the game is not compatible. I've tried DOS, and making it compatible but there is something I'm not doing correctly.
