First post, by max35
i am new in ubuntu wine, can anyone help me how to use dosbox megauild on ubuntu wine?
Use the regular 0.74 without wine.
i need the print function of dosbox megabuildh in ubuntu wine, i am able to use dosbox 0.73 version no print setttings in dosbox conf.
Megabuild will work just fine on wine as it will work on regular windows. But for using the printing options of the megabuild you must first make sure that you can print in wine. If that doesn't work then the megabuild cannot work. If it works then look at the megabuilds site and in the forum here for what you need to print with the megabuild and try if that works on wine, too.
