First post, by JackGreen
7th Guest Just hangs when I do a Install on Vista it does not even install.
open DOSbox and type in the following:
Z:\> mount d e:\ -t cdrom
Then it tells me that the MSCDEX is installed and that the D: drive is mounted as CDRom e:\
I then type:
Z:\> mount c c:\t7g
(I created a file in the C: drive...right when I opened up to explore the C: Drive is where I created the “t7g” folder)
Then it tells me Drive C: is mounted as local directory C:\t7g\
Next:
Z:\ c:
Then:
C:\ d:
Then I type:
D:\> dir /w
and run the
install.bat
I dont know what configurations to use but use the default and then it freezes and does not show a install directory.
What am I doing wrong
Reply 1 of 10, by Anonymous Freak
Just to make sure, are you installing from Disc 2 or Disc 1?
Reply 2 of 10, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Why mounting drive D as E:? Why not mounting it as D?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 10, by SKARDAVNELNATE
Installation requires AUTOEXEC.BAT and CONFIG.SYS. Otherwise it stops at README.TXT.
In C:\t7g, the folder you mounted, create 2 text documents. Rename them AUTOEXEC.BAT and CONFIG.SYS without any .txt extension. It's okay if they're blank, the installer just looks for them to be there.
I often find the order of the statements confusing. "The D: drive is mounted as CDRom e:" sounds kind of backward. If you look at his commands, "mount d e:\ -t cdrom", he mounted optical drive E:\ as D.
Reply 4 of 10, by JackGreen
I created the dummy files and installed from disc 2 first and had trouble installing disc 1. I am a serious newbie here so bear with me.
Reply 5 of 10, by JackGreen
I use e drive because my d drive is a partition.
Reply 6 of 10, by JackGreen
Disc 1 right now I already installed from disc 2
Reply 8 of 10, by eL_PuSHeR
Okay. I got it backwards. 😁
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 10, by JackGreen
Yeah
Reply 10 of 10, by SKARDAVNELNATE
Sounds like you successfully installed it and are now playing it. Glad we could help.
JackGreen wrote:
Installed on second disk only having problems with the first disk
Oh? What problem are you having with the first disc?
Suggestions: Read the manual, the README.txt file, section on RESCAN
There's also a patch for this game.
