7th Guest
First post, by JackGreen
7th Guest Just hangs when I do a Install on Vista it does not even install.
open DOSbox and type in the following:
Z:\> mount E:\ -t cdrom
Then it tells me that the MSCDEX is installed and that the D: drive is mounted as CDRom e:\
I then type:
Z:\> mount c c:\t7g
(I created a file in the C: drive...right when I opened up to explore the C: Drive is where I created the “t7g” folder)
Then it tells me Drive C: is mounted as local directory C:\t7g\
Next:
Z:\ c:
Then:
C:\ E:
Then I type:
E:\> dir /w
and run the
install.bat
Installed on second disk only having problems with the first disk
What am I doing wrong
Reply 2 of 4, by JackGreen
yes but nobody answered me and left the post
Reply 3 of 4, by wd
Rank DOSBox Author
DOSBox Author
And cluttering the forums with the same posting makes magically answers appear rather than annoys people?
Reply 4 of 4, by SKARDAVNELNATE
I replied to the original topic.
