First post, by miami
i have a problem When I write a date or a number, I am obliged to do on/off NumLock for the number can be validated.
how to turn ON NumLock when i start DosBox
best
best
I thought about the same problem and then I've written a "very little" program to do that. Just put it to the directory where dosbox will go into after start and add in the configfile in the autoexec area:
locks.exe
There are also other possibilities but don't ask me ^^
Hope that will help you.
have fun
PS: Please write me a line if it works or not =) ... thank you
wrote:PS: Please write me a line if it works or not =) ... thank you
do not work for me,
i have put locks.exe in the folder where the program is :
C:\MV\CG.exe
C:\MV\locks.exe
and also add in the configfile "DOSBox 0.74 Options.bat" in the autoexec area:
locks.exe
C:\DOSBox-0.74\DOSBox 0.74 Options.bat
Thank's again!
hmm that's bad 🙁 ... please let me know what is that CG ? What's that for a program ? And is it possible to download it from somewhere ?
Hmm -.- ....
You need to start dosbox with numlock turned on and that's it or what am I wrong ? If I'm wrong, please explain your problem in detail 😀 ... I think this could turn very interesting ^^
thank you Vince.Bloodworks,
i have download DOSBOX Megabuild 5 and run correctly NumLock
thank's to h-a-l-9000 for MB5 http://home.arcor.de/h-a-l-9000/
best
Thanks! Works for me!
That's what I did:
1) Copy locks.exe to program's folder.
2) Make a batch file
run.bat:
locks.exe
<My good old Clipper app>.exe
3) Run run.bat
There was no need to modify [autoexec] section.
But
3) Run run.bat […]
locks.exe
3) Run run.bat
is what you put into the [AUTOEXEC] section usually.
Klimawandel.
hello, another solution is in the removed [dos] put the line Numlock = ON
Thanks for reviving a 4-year old thread with nothing relevant!
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
Emaculation: https://www.emaculation.com/forum (as macplus)
So how to launch DOSBox with same NUMLOCK status as host machine?
Is this too much voodoo?
Vince.Bloodworks wrote on 2010-09-10, 10:35:I thought about the same problem and then I've written a "very little" program to do that. Just put it to the directory where do […]
locks.exeThere are also other possibilities but don't ask me ^^
have funPS: Please write me a line if it works or not =) ... thank you
Your little program worked for me solving this little annoyance, thanks.
SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
