First post, by Mau1wurf1977
I had my eyes on it, but for the time being will play with Socket 7 hardware. I liked that this board had PCI and IDE and FDD on the board. It also looks quite new and has a good chipset.
But 66 euros? WOW
Anything special about this board? There must be a reason why it fetched such a high price.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItemn … 0633137860.html
Reply 1 of 15, by Amigaz
It's one of the last 486 boards made but nothing special really, I use to have one...no EDO RAM support...slow PCI performance.
I guess this means it's time to sell of my last batch of unused 486 motherboards 😁
Reply 2 of 15, by ux-3
Look at the Dallas clock chip. It translates: Trouble!
Retro PC warning: The things you own end up owning you.
Reply 3 of 15, by Amigaz
If I remember correctly it was socketed so it's easy to pop in a new one (yes, they can still be bought new)
Reply 4 of 15, by Tetrium
Mau1wurf1977 wrote:
I had my eyes on it, but for the time being will play with Socket 7 hardware. I liked that this board had PCI and IDE and FDD on […]
But 66 euros? WOW
I got 2 of those boards actually. Iirc the later version had PS2 mouse support but neither of the boards I have have that as I got the older versions.
Lemme look up a pic I posted earlier...
Edit: Here it is:
Reply 5 of 15, by ux-3
the dallas chip in that auchtion doesn't look as if in a socket
Reply 6 of 15, by Tetrium
I could check on my boards. How do I tell if the DALLAS is socketed or not? (except by pulling hard 😜 )
Edit: Found this:
Replacing the Dallas real time clock on a 486 mobo
Seems they are socketed for the newer versions 😉
Reply 7 of 15, by Mau1wurf1977
What is the issue with this "dallas chip"?
Hmm but wouldn't it be a lot better than ISA only boards or VLB boards?
Does one really need speed for a 486? You might as well go with a Pentium. I saw these 486s for compatibility with Games that don't run on a fast Pentium. And with the Turbo button you can turn it into 386 speed.
Reply 8 of 15, by Tetrium
It's better then ISA and also better then VLB, the latter because of the varied choice of PCI cards we have today.
Do we -really- need the speed of the 486? I dunno, but probably we do since theres so many on these forums who have a working 486 😜
I have one, though I've barely used it in the last 2 years or so.
Reply 9 of 15, by Mau1wurf1977
Cool!
Well I got my 2 Super Socket 7 boards! I was thinking about bidding for the third one, as the seller has some cheap 1$ item but he doesn't want to do combined postage so I will likely pass...
My YouTube channel
Reply 10 of 15, by Amigaz
Tetrium wrote:
It's better then ISA and also better then VLB, the latter because of the varied choice of PCI cards we have today. Do we -really […]
Can't agree with you fully here....a good socket 3 mobo with VLB slots can have better or equal performance when it comes to gfx cards
Good PCI performance on a socket 3 board is handy when it comes to demandning SVGA games from the 486 era
Reply 11 of 15, by ux-3
But wouldn't those games love to run on a P1 or better?
Reply 12 of 15, by Amigaz
Yep, but then you're sitting with a Pentium cpu that have some problems with earlier games...."you can't have the cake and eat it too" 😉
Reply 13 of 15, by TheLazy1
None of my 486 boards will POST with a Voodoo3 installed, they seem to be very picky so I wouldn't buy one on PCI alone.
Reply 14 of 15, by Amigaz
yep, but it's a bit of a waste using such a card on this kind of system since the whole board is a big bottleneck
Have tested around 25 different types of socket 3 mobo's with PCI bus, haven't ran into any incompatability issues with any PCI gfx card so far (ATI, S3, WD, Tseng etc)
Reply 15 of 15, by swaaye
I got a Voodoo3 going but unless I used some old drivers it would BSOD with a 486-like CPU installed. Later drivers worked with a Pentium Overdrive so I imagine that at some point they switched to using some Pentium instructions.
But yeah if you want to play games that use 3D acceleration, you shouldn't be messing with a 486 system in the first place. 😀
