First post, by Vince.Bloodworks
- Newbie
Hi guys,
I've got a problem with the resolution in dosbox. I've downloaded the new nvidia driver 258.96(I've got the same problem with drivers younger then 176...) and when I run dosbox I've got a relativly small output. Before I used configurations like scaler=normal3x and a resolution of 960x600 to get fullscreen in my games. I tried out every output method, resolution and scalersettings but nothing will work. I've downloaded the dosbox faq from this link: DosBox FAQ but it didn't help me. Any help would be great.
I'm using a NVidia GeForce 7600 GT with the driver you can read above and a Fujitsu Siemens P15-1 TFT (which forced me to set scalers on way back...).
The Dosbox versions are from 0.70 to 0.74.
Thank you.
