First post, by Amigaz
- Oldbie
I'm fiddling with an Asus V7700 Geforce 2 Ti 64mb card in my Via based crappy Fujitsu Siemens rig...
The fan was making alot of noise so I decided to remove the heatsink to clean/lubricate the fan and aplly fresh thermal compond...
After I cleaned the GPU from old, hardened thermal compound the name "Geforce 2GTS" appeared on it (???!!)
According to the info I've read on the internet the GPU's should be named "Geforce 2 Ti", "Geforce 2 Ultra" etc etc
Was this a scam from Asus side?
And I didn't get a higher 2dmark 2001se score with this card compared to my Asus Geforce 2 GTS 32mb 😜
