First post, by eirinjas
I just wanted to tell other DOSBOX users how I got Battlespire to run. It initially ran okay, but then I applied the 1.5 patch and it just kept complaining about not having enough memory and threatening to crash, which it did - repeatedly. It became unplayable. So I hit the forums here, tried every suggestion, but nothing helped. So I did some searching and I actually found a clue on a Russian forum when looking up the "causeway error". So here it is:
Open up Spire.bat in a text editor. Drop down to the line that reads:
set causeway=MAXMEM:40;PRE:40;NAME:spire.swp
and change the MAXMEM to 71, like so:
set causeway=MAXMEM:71;PRE:40;NAME:spire.swp
Save.
Then mount your cue/iso. Voila! It runs great now, minus some framerate issues, but that's another issue.
Before I edited the Spire.bat the game would find 31 megs + swap on start, now it finds 62 megs + swap.
Reply 1 of 2, by eirinjas
Oh, I guess I should point out the need to set the DOSBOX memsize to something above 40. I set it to 63 for Battlespire, and the 1.5 patch for Battlespire recommends a setting in the Spire.cfg file. I thought I should make those clarifications, however, the game did not run until I made the MAXMEM change.
Reply 2 of 2, by nitro322
Hey, I know this post is a few months old, but just wanted to say thanks for the tip. I ran into the same problem and this was exactly what I needed. Thanks for taking the time to post it here.
