First post, by realnc
- Oldbie
It's impossible to scale the picture to 1280x1024 when using "vgaonly" as machine type. I mainly use these settings:
fullresolution=1280x1024
output=openglnb
machine=svga_s3
scaler=none
But there is one game that doesn't work with svga_s3 and only works with vgaonly: Ultima 8. (This game stalls when moving the mouse (CPU utilization drops to almost 0%), and since you move the mouse when you walk, fight and interact with objects, svga_s3 makes the game unplayable.)
However, with vganormal DOSBox will not scale the output and only get a small window at the center of the screen.
I tried various scalers (normally I use "none"), like normal3x and other 3x scalers, but nothing works with vgaonly. Setting aspect to "true" also won't have any effect.
Linux 64-bit, DOSBox SVN and 0.74.
