First post, by Good Ol' TarviS
Hello there. I have DOSBOX setup to use Timidity++, which is using the WeedsGM3 soundfont.
I have a small problem though: while it sounds great, the game freezes for a second or so whenever the music changes.
Because this game has dynamic music, it happens often.
It doesn't seem to happen in other games.
Any advice?
EDIT: Also I should note that it strangely doesn't occur on the first floor, but it does on the second.
EDIT2: I got it working smoothly by using Timidity++ through Midi Yoke instead of having DOSBOX use it directly.
