First post, by Zaxxon
I used to use my virtual cdrom moutned with dosbox with no problems soem times ago,but recently i had to format my hd,reinstall both dosbox(0.74) and daemon tools.now,everytime i mount an iso with it,and then starting dosbox,any application that uses the cd(the daemon tools one)its super slow,its like its emulating a 4x cdrom or something like that,while before i installed games in a snap.what could it be?
Reply 1 of 5, by eL_PuSHeR
[Moved to DOSBox General Section]
Reply 3 of 5, by leileilol
Cycles aren't max?
long live PCem
Reply 4 of 5, by Zaxxon
yes cycles are a max,games go maybe too fast even,so its not that.its like its reading from an old cd reader.i never had this problem before
i mount them with daemon tools because its easier..do i have to mount them as image on dosbox or cdrom?
Reply 5 of 5, by collector
If you are still having to mount a CD in DOSBox you are not saving any steps. Just use imgmount instead of mount and take Daemon Tools out of the equation.
