Cannot use CTRL-PAUSE
First post, by wolfgang
I am trying to use QBASIC in DosBox. It works great, except I can't break an infinite loop. QBASIC provides the CTRL-PAUSE command while the program is running to stop the program, but this doesn't work in DosBox. I have tried to see if there is a keystroke already mapped to this by DosBox, but can't find anything. Any ideas?
Reply 2 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Most BASIC interpreters and compilers will recognize Ctrl-ScrollLock as a Break, because that was the Break key on PC XT-style keyboards.
Reply 3 of 5, by TeaRex
Maybe this should be in the README? Since using CTRL-SCRLK instead of CTRL-BREAK it is not exactly an obvious thing (to most people) and the question about CTRL-BREAK has been asked several times already.
tearex
Reply 4 of 5, by mr_bigmouth_502
I second this.
Reply 5 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Various forms of BASIC recognize the keypress, but Ctrl-ScrollLock is not a generic substitute for Ctrl-Break. DOSBox does not implement true Break processing in its emulated BIOS and DOS. Not sure it's worth mentioning in the readme/manual when it pertains mostly to BASIC.
