First post, by retro games 100
- l33t
I have a Media Magic Opti 82C929A sound card. I went to DriverGuide.com to get the driver. Amazingly there was one, with the same FCC Id number. Needless to say, it didn't work. Win98 couldn't see the downloaded driver, so I tried the DOS install instead. It needed to be run from a floppy disk, so I did that, but I suspect the folder structure wasn't as the installer was expecting. Nevertheless, it partially worked - a few things failed, like it couldn't find the test .WAV files, and there seemed to be some confusion over hardware resources.
The sound card test played FM music OK though. But when I run Doom, it crashes weirdly on the init part where it tries to look for resources such as sound cards etc. BTW, the DOS driver from DG.com said "MAD 16" on the screen. Is that correct?
Does anyone have another Opti 82C929A DOS driver I can try please? Thanks a lot.
