First post, by xsare
Hello, I've a serious issue with dosbox 0.74 on my hp 625 notebook (linux).
If i start dosbox the system freezes for about 2 seconds in an interval of 10 seconds. The cpu goes to 100% while the system freeze.
I can move the mouste but no application (including dosbox) is reacting.
This happens witout any application or game is started in dosbox. only dosbox itself is running.
Operating System:
linux mint 10
kernel linux 2.6.35-22-generic
Gnome 2.32.0
Hardware:
HP624
CPU: AMD Athlon II P320 DualCore
RAM: 4GiB
Please let me know if you have any idea, how to solve this issue.
Thanks in advance,
xsare
Reply 2 of 11, by xsare
Thanks for your fast answer. But i am sorry. frameskip does not solve the problem.
While dosbox run the cpu perfomance is:
about 20% (if no "lag")
then (every 10 seconds) it jumps to 100% for about 2 seconds.
But not every cpu (dual-core) goes up to 100%! While one goes to 100% the other cpu goes down (about 0-10%)...
I wonder why it is exactly an interval of 10 seconds....
I found another interessting thing. If i use the notebook with external power supply the lag-intervall is about 30 seconds. if akku is use 10 seconds....
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
sounds like your cpu scheduling might be interfering.
have you tried disabling it, to see if it influences something ?
cpufreq-selector -g performance
Water flows down the stream
Reply 4 of 11, by xsare
No i tried the cpufreq-selector -g performance (and powersave). No difference.
I think the cpu jump to 100% perhaps is only an result of the lags, not the cause. But i dont know...
And somtetimes the cpu only jumps to about 70%. But the system lags, too.
    55.08 KiB
    You can see 2 freezes...
Reply 5 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Just a shot in the dark but try to disable everything in the config file that can be disabled, like sound, joystick etc.
Have you tried a different output method? (output=...)
1+1=10
Reply 7 of 11, by HunterZ
Have you checked the Process tab in the program in that screenshot to see which specific program/process is taking up 100% of the CPU during those usage spikes?
Reply 8 of 11, by Jorpho
What is that program, anyway? Looks nifty. (I can't stand thwacking through various arguments for "ps" on the command line trying to find out what's going on.)
Reply 10 of 11, by xsare
Actually i could not reproduce the posted issue. I figgured out that something was wrong with my cpu(-controlling). One of the cpu ran at 1500Mhz the other at 2100. (2100 is right).
After restarting the System i have no further problems.
I will keep an eye on this...
Thanks for all your help.
