Bugs in DOSBOX?
First post, by lsjunii
I am a new with Dosbox.
I used an old program for serial communication on Win-XP.
My problems which I couldn't find out on this board are..
1. I can't launch the screen saver. The saver couldn't be executed after installing Dosbox.. Is there a solution for this?
2. In the old program, the reading of time is very odd.
" Date: Dec 1, 2010 Time: 184:58:4"
I can convert the hour (3 digit!!!) to day and time.
But the display is complicated.
labmaster.
Reply 1 of 4, by dosquest
Inter net play nor printing has been integrated into this version of dosbox.
Reply 2 of 4, by Jorpho
I have no idea what screen saver you are talking about.
2. In the old program, the reading of time is very odd. " Date: Dec 1, 2010 Time: 184:58:4" I can convert the hour (3 d […]
If it is an old program, it may not understand dates after the year 2000, and you would get this same behavior on a real DOS machine.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
the time problem looks pretty cool 😀
Water flows down the stream
Reply 4 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Probably ran a few days
1+1=10
