First post, by HunterZ
- l33t++
I'm just wondering what USB-MIDI interfaces people are using, and under which OSes, and how well they work.
I originally purchased an early version of the M-Audio MIDISport Uno a few years ago to use under Windows XP, to interface DOSBox with my Roland SC-88 and MT-32 synths. It worked fine (occasional buffer overflows on the MT-32 unless I slowed DOSBox down) until I built a new Win7 x64 desktop, where it became unusable because M-Audio was dragging their feet working on 64-bit drivers.
Out of frustration, I then purchased an E-mu (aka Creative) Xmidi 1x1 Tab early this year. It worked fine in Windows 7 x64 at first (as far as I could tell), but after more extensive use recently I discovered that it has some issues with MT-32 SysEx checksum errors. Even worse, QFG1EGA and QFG2 sound wrong in DOSBox and ScummVM for some reason even if I slow down the SysEx to avoid the checksum errors. I tried testing with both E-mu and Microsoft drivers for the device, and the result is the same.
I recently switched back to my MIDISport Uno, having noticed that M-Audio finally released Windows Vista/7 x64 drivers a month or two ago. It seems to work fine other than the old buffer overflow issues, so I guess I'll put the E-mu back in the storage bin that the M-Audio had been sitting in (the irony!).
I did send a support request to E-mu, and got a response that wasn't particularly helpful ("uninstall your M-Audio interface and try again" etc.). I'm debating whether to jump through their hoops just to see what happens, but I know nothing will come of it.
