First post, by MatthewBrian
I just removed an S478 processor heatsink. It has never been removed since it was purchased new back in 2002.
To my surprise, the heatsink popped out along with the processor sticked below that. I tried to remove the processor from the heatsink and it won't be removed. (The heatsink has a "mat" with rubber-like thermal paste on it, and the processor is "glued" by the rubber-like thermal paste).
Is there any way to separate the processor and the heatsink?
At the moment I can't put the processor back since I had to pull up the ZIF lever but with the big height of the CPU+heatsink module it is impossible to pull up the ZIF, put the processor then lock it back.
