First post, by rcblanke
- Oldbie
Hi all,
The following major new features were added:
* Reorganization of VirtualBox into a base package and Extension Packs; see chapter 1.5, Installing VirtualBox and extension packs, see the manual for more information
        * New settings/disk file layout for VM portability; see chapter 10.1, Where VirtualBox stores its files, see the manual for more information
        * Major rework of the GUI (now called “VirtualBox Manager”):
              o Redesigned user interface with guest window preview (also for screenshots)
              o New “scale” display mode with scaled guest display; see chapter 1.8.5, Resizing the machine’s window, see the manual for more information
              o Support for creating and starting .vbox desktop shortcuts (bug #1889)
              o The VM list is now sortable
              o Machines can now be deleted easily without a trace including snapshots and saved states, and optionally including attached disk images (bug #5511; also, VBoxManage unregistervm --delete can do the same now)
              o Built-in creation of desktop file shortcuts to start VMs on double click (bug #2322)
        * VMM: support more than 1.5/2 GB guest RAM on 32-bit hosts
        * New virtual hardware:
              o Intel ICH9 chipset with three PCI buses, PCI Express and Message Signaled Interrupts (MSI); see chapter 3.4.1, “Motherboard” tab, see the manual for more information
              o Intel HD Audio, for better support of modern guest operating systems (e.g. 64-bit Windows; bug #2785)
        * Improvements to OVF support (see chapter 1.12, Importing and exporting virtual machines, see the manual for more information):
              o Open Virtualization Format Archive (OVA) support
              o Significant performance improvements during export and import
              o Creation of the manifest file on export is optional now
              o Imported disks can have formats other than VMDK
        * Resource control: added support for limiting a VM’s CPU time and IO bandwidth; see chapter 5.8, Limiting bandwidth for disk images, see the manual for more information
        * Storage: support asynchronous I/O for iSCSI, VMDK, VHD and Parallels images
        * Storage: support for resizing VDI and VHD images; see chapter 8.21, VBoxManage modifyhd, see the manual for more information.
        * Guest Additions: support for multiple virtual screens in Linux and Solaris guests using X.Org server 1.3 and later
        * Language bindings: uniform Java bindings for both local (COM/XPCOM) and remote (SOAP) invocation APIs
In addition, the following items were fixed and/or added:
* VMM: Enable large page support by default on 64-bit hosts (applies to nested paging only)
        * VMM: fixed guru meditation when running Minix (VT-x only; bug #6557)
        * VMM: fixed crash under certain circumstances (Linux hosts only, non VT-x/AMD-V mode only; bugs #4529 and #7819)
        * GUI: add configuration dialog for port forwarding in NAT mode (bug #1657)
        * GUI: show the guest window content on save and restore
        * GUI: certain GUI warnings don’t stop the VM output anymore
        * GUI: fixed black fullscreen minitoolbar on KDE4 hosts (Linux hosts only; bug #5449)
        * BIOS: implemented multi-sector reading to speed up booting of certain guests (e.g. Solaris)
        * Bridged networking: improved throughput by filtering out outgoing packets intended for the host before they reach the physical network (Linux hosts only; bug #7792)
        * 3D support: allow use of CR_SYSTEM_GL_PATH again (bug #6864)
        * 3D support: fixed various clipping/visibility issues (bugs #5659, #5794, #5848, #6018, #6187, #6570)
        * 3D support: guest application stack corruption when using glGetVertexAttrib[ifd]v (bug #7395)
        * 3D support: fixed OpenGL support for libMesa 7.9
        * 3D support: fixed Unity/Compiz crashes on natty
        * 2D Video acceleration: multimonitor support
        * VRDP: fixed rare crash in multimonitor configuration
        * VRDP: support for upstream audio
        * Display: fixed occasional guest resize crash
        * NAT: port forwarding rules can be applied at runtime
        * SATA: allow to attach CD/DVD-ROM drives including passthrough (bug #7058)
        * Floppy: support readonly image files, taking this as the criteria for making the medium readonly (bug #5651)
        * Audio: fixed memory corruption during playback under rare circumstances
        * Audio: the DirectSound backend now allows VMs to be audible when another DirectSound application is active, including another VM (bug #5578)
        * EFI: support for SATA disks and CDROMs
        * BIOS: reduce the stack usage of the VESA BIOS function #4F01 (Quake fix)
        * OVF/OVA: fixed export of VMs with iSCSI disks
        * Storage: Apple DMG image support for the virtual CD/DVD (bug #6760)
        * Linux host USB support: introduced a less invasive way of accessing raw USB devices (bugs #1093, #5345, #7759)
        * Linux hosts: support recent Linux kernels with CONFIG_DEBUG_SET_MODULE_RONX set
        * Guest Additions: Shared Folders now can be marked as being auto-mounted on Windows, Linux and Solaris guests
        * Linux Additions: Shared Folders now support symbolic links (bug #818)
        * Linux Additions: combined 32-bit and 64-bit additions into one file
        * Windows Additions: automatic logon on Windows Vista/Windows 7 is now able to handle renamed user accounts; added various bugfixes
