First post, by Svenne
I got NFS SE for christmas by my parents. Problem is it won't run on Windows 98. When I run the installer I get an error message about INFSW.EXE wich I cannot switch to. After closing it I get two "illegal exception" messages about the same program.
INFSW orsakade ett ogiltigt sidfel imodul <okänd> på adress 0000:0b75fc5d.Registrerar:EAX=bff87fe9 CS=0167 EIP=0b75fc5d EFLGS=00010246EBX=bff87fe9 SS=016f ESP=005c00e0 EBP=005c0100ECX=005c0184 DS=016f ESI=8196ffe0 FS=41a7EDX=bff76855 ES=016f EDI=005c0278 GS=0000Byte på CS:EIP:Stackdump:bff76849 005c0278 bff87fe9 005c01ac 005c0184 005c0564 bff76855 bff87fe9 005c0194 bff87fe9 005c0278 bff87fe9 005c01ac 005c0184 0b75fc5d 005c02ec
INFSW orsakade ett ogiltigt sidfel imodul INFSW.EXE på adress 0167:0041d285.Registrerar:EAX=00000000 CS=0167 EIP=0041d285 EFLGS=00010206EBX=004816e8 SS=016f ESP=005cf208 EBP=005cf3e0ECX=00000000 DS=016f ESI=000000ac FS=4057EDX=005cf2bc ES=016f EDI=00000000 GS=0000Byte på CS:EIP:8b 08 50 ff 51 2c 83 3d f0 d6 43 00 00 74 0d 68Stackdump:005cf2bc 005cf210 000000ac 00000000 00000000 2bc60000 2bc605c8 405717b7 047c0000 824e17b7 17b79f4a 000205c8 00000502 005cf270 81909050 8196c0bc
System specs:
* Intel Pentium II 400 MHz.* Acer V66XA motherboard.* ATi Rage Pro Turbo 4mb graphics.* 256 mb RAM (128x2).* Windows 98 SE.* KernelEx 4.5 RC5.* Revolutions Pack 9.7.0.* DirectX 9.0c.Suggestions please?
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
