First post, by vomi
I use a DOSBox for running my old DOS programs. It works (almost) well and allow me to use DOS programs in Windows 7.
But I have 2 problems with keyboard.
On numeric part the Num lock should be on, but I must always press NumLock twice on the beginning to start typing numbers.
Second problem is with Caps lock. If I want to change caps I must always pres Caps lock twice to change size of letters. I have set keyboard to auto and try this in DOSBox windows without running any programs (like command prompt) and problem is the same.
I use DOSBox 0.74 & Win 7 Ultimate 64 bit. Same is on Win 7 Pro 32 bit.
This is very disturbing. 🙁
Can you help me?
