First post, by maldron
Hello all. I just got this lap top and tried out dosbox on it. It is an HP pavillion running windows 7 64 bit. The keyboard works perfectly fine normally, but when i ran dosbox (it was the win32, so I thought that might have something to do with it, but couldn't find a 64 anywhere), I cannot press the '\' key, which is a major problem. When I press the \ key, ] appears instead, and thus when i pess the ']' key, [ appears, and when I press the '[' key, nothing appears. I have never seen this happen before so I as wondering if this had happened to anybody else or if I should download a different version.
Thank you
Tim
Reply 1 of 2, by maldron
I should add that all the other keys work perfectly fine, and only those 3 are goofy.
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
there is a thread in the development forum on this. It has to do with the drivers that HP installs. It's one of the stickies
Water flows down the stream
