New S3 card for me.
First post, by Shagittarius
Just got an old S3 Trio 3D 'on board' card from a machine someone brought in at work to throw away. It's a 3.3v AGP card. I was just wondering is there another name for this card I can't find any real info on it.
Also does anyone know anything about this board, would it be better than a rage board in a P90 DOS machine?
**Since my chronology was all off on this I'm not even sure it has a rage board in it. I'll have to check on that again too.
Sorry don't know too much about it, thanks for any info you have.
Reply 1 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What's the 86Cxxx number on the chip?
1+1=10
Reply 2 of 11, by Shagittarius
86C365
Reply 4 of 11, by Markk
If you use a socket 7 m/b for P90, I don't think it's going to have an AGP socket.
Reply 5 of 11, by Shagittarius
Right, I'll have to check it again, I guess it would be more likely to have a VLB slot? hmmm...gotta take a look.
Reply 6 of 11, by Old Thrashbarg
No, only a few really early Pentium boards had VLB slots. The majority of Socket5/7 boards were PCI.
Reply 7 of 11, by Shagittarius
Oh thanks of course, my chronology is all messed up. So AGP > PCI > VLB?
Reply 8 of 11, by DonutKing
No VLB was the earliest, it appeared in the 486 era andcould be problematic at higher bus speeds.
PCI appeared in late 486 boards as a replacement for VLB and most socket 5/7 boards had PCI slots. Some early pentum boards had VLB slots but this was very short lived.
AGP was more common in the Pentium 2 era. Most early P2 boards had AGP while very few socket 7 boards did.
There was an extension to socket 7 called , funnily enough, super socket 7 mainly for 100mhz FSB support but many of these had AGP as well. These were usually paired with an Amd K6 CPU or similar, rather than a pentium and competed with the pentium 2.
Reply 9 of 11, by Shagittarius
Sorry I meant that in order of power, but yes I see what you are saying. I shouldn't have said chronology and then went on to rank them backwards like that.
Reply 10 of 11, by Tetrium
In those days it mattered little if you had an AGP or PCI card anyway.
AGP really started to take off at, say, the time AGP 4x became mainstream.
My retro rigs (old topic)
Report spammers here!
Reply 11 of 11, by Shagittarius
Took a look, it turns out It's a Socket 5 board but does indeed feature PCI/ISA slots only.
Looks like I have no real use for that S3trio yet.
The video board installed shows up as an 'ATI Pro Turbo PCI atim64 - GX'.
I think I'll go see if I can add this machine to the 3dbench list I noticed there were no P90s on it =).
Im using that machine to post this on Win98, its got 80MB of ram which is almost enough to have an enjoyable cruise on the net but it's still pretty slow for all sites except vogons.
I'm running on at the mouth, thanks everyone for your help earlier.
