theme park dosbox
First post, by huntingbears7
Tried to install it first time and it didn't work because i had changed the name of the main.exe file, then I try again and it says you must use the floppy disk drive!! why did it suddenyl decide i needed to use the floppy disk drive???
also it runs way to quick on the menu but when i change the frame rate in dosbox it makes no difference
why is it so hard to play them park!!???
Reply 1 of 3, by rcblanke
Why is it so hard to write them proper game problem reports?
Reply 2 of 3, by huntingbears7
what info do you need? im running vista
Reply 3 of 3, by Jorpho
Start with the 60 seconds guide.
60 seconds guide to getting your game to run in DOSBox
Why did you change the name of the .exe file?
What do you mean by "it didn't work" ? If it's running way too quick on the menu, does that mean that you can get it to work after all?
What "mount" commands are you using?
Are you using an original CD, or did you download this from somewhere?
