First post, by CU_AMiGA
Hi
Does anyonme have or know where i can get the drivers for the Panasonic/Creative CR-563 CD-ROM drive? Thanks for your time.
Regards
Reply 1 of 6, by Davros
you need to search for a file called SBCD.SYS (dont have a link try driversguide or similar)
In your CONFIG.SYS add the following: (if your booting from hdd and not a floppy change accordingly)
DEVICE=A:\SBCD.SYS /D:WINCDROM
Then modify your AUTOEXEC.BAT and add the following:
A:\MSCDEX.exe /D:WINCDROM /V
Reply 4 of 6, by doomer
Here are the official Panasonic CR-563 CD-Rom drivers.
ftp://ftp.panasonic.com/pub/Panasonic/Drivers/OEM-CDROM/
Try 56X_DOS.EXE or this one. One of them should do it, I think.
You should also consider SBCD.SYS. If others report it to work, it must work.
Reply 5 of 6, by Robin4
I have also the drivers for this cd-rom..
    cr563b.zip
    85.22 KiB
    196 downloads
