First post, by rick12373
- Oldbie
Recently many of you gave me great advice on my questions about the Voodoo 1. The Pentium 2 that will eventually get this card works quite well but I think that maybe the autoexec.bat and config.sys could use an experts eye. I have 619k of conventional memory which is good, but a few games behave strangely sometimes.
Here are the files in question:
Config.sys:
DOS=HIGH,UMB
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF /Q
DEVICE=C:\DRIVERS\UMBPCI.SYS /I=D800-EFFF
DEVICE=C:\WINDOWS\EMM386.EXE X=D800-EFFF X=B800-C7FF I=C800-D7FF I=B000-B7FF RAM M3 D=256 AUTO
FILES=40
DEVICE=C:\CTCM\CTCM.EXE
DEVICE=C:\WINDOWS\SETVER.EXE
LASTDRIVE=Z
DEVICEHIGH=C:\CDROM\CDROM.SYS /D:RADISH
Autoexec.bat
@ECHO OFF
SET MGA=C:\MGA\SETUP\
c:\mga\setup\vbetsr
c:\mga\setup\vbesetup
SET DIRCMD=/W /P
LH C:\windows\command\MSCDEX.EXE /D:RADISH /M:10
SET SOUND=C:\SB16
SET BLASTER=A220 I5 D3 H7 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
SET CTCM=C:\CTCM
PATH=C:\XX;C:\MOO31;C:\WINDOWS\COMMAND;
LH C:\SB16\DIAGNOSE /S
LH C:\SB16\AWEUTIL /S
LH C:\SB16\MIXERSET /P /Q
LH C:\MOUSE\CTMOUSE.EXE
C:\MOO31\MOO.BAT MENU
Is there anything missing or stuff that doesn't need to be there?
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
