Linux/ALSA midi?
First post, by ste
Love DosBox, no problems other than getting midi working..
When I startt dosbox I get this:
ALSA:Can't subscribe to MIDI port (65:0)
MIDI:Can't open device:alsa with config:.
MIDI:Opened device:none
cat /proc/asound/seq/clients shows this:
Client info
cur clients : 2
peak clients : 3
max clients : 192
Client 0 : "System" [Kernel]
Port 0 : "Timer" (Rwe-)
Port 1 : "Announce" (R-e-)
Connecting To: 63:0
Client 63 : "OSS sequencer" [Kernel]
Port 0 : "Receiver" (-we-)
Connected From: 0:1
I'm not too familiar with midi and alsa.. any ideas?
Resurecting my youth one game at a time
Reply 1 of 4, by prompt
You don't seem to have any midi driver loaded. Check if ALSA has midi support for your soundcard. If not, you can use either timidity or fluidsynth to simulate midi sound but both need much cpu power.
Reply 2 of 4, by Harekiet
Rank DOSBox Author
DOSBox Author
Might wanna try setting config=63:0 under the midi section in the config file and setting the device=alsa
Reply 3 of 4, by ste
Yeah, looks like ALSA doesn't support midi on my chip yet. 😒
How do I get timidity to work with dosbox - I can't seem to see anything in the man page or README file. I have timidity all set up and working (as in I can play midi files)
Thanks!
Reply 4 of 4, by prompt
Execute it with "timidity -iA" then it becomes an ALSA server at port 128:0. You have to set the port in the dosbox config file.
note: timidity will be more accurate if it is run as root.
