First post, by McSquirrel
Hi,
I'm using DOSBox 0.74 on my Apple MacBook Pro (bought December 2009, running Mac OS X 10.6.6), and it works nice.
However, when I tap the touchpad (instead of clicking it), the simulated left-click may be too short for some games to recognize it.
The game where I experienced this is a German adventure called "Das Erbe":
http://www.mobygames.com/game/dos/das-erbe
http://www.kostenlosespiele.org/Das-Erbe.html
The mobile version of DOSBox seems to have some special SDL configuration variables for touchpads (called "touchpadmouse" and "clickms"):
# This is the configurationfile for DOSBox 0.73.
# Lines starting with a # are commentlines.
# They are used to (briefly) document the effect of each option.
[sdl]
# fullscreen: Start dosbox directly in fullscreen.
# rotateright: Alternate screen rotation.
# mapperfile: File used to load/save the key/event mappings from.
# kbdtoolbar: First toolbar.
# gametoolbar: Second toolbar.
# settoolbar: Third toolbar. Note: frameskip and cycles values are drawn there.
# usescancodes: Avoid usage of symkeys, might not work on all operating systems.
# sensitivity: Mouse sensitivity.
# touchpadmouse: Emulate mouse with stylus moves on screen. Can fix mouse behavior in games that expect only relative mouse movement.
# clickms: When in touchpad mode, left-click is sent after single-tap. This sets the delay in milliseconds between emulated mouse button down and up events.
# rightclickdelay: Touchpad mode. If you tap and hold stylus for this milliseconds, right-click will be send instead of left. 0 to disable.
# dpadmouse: Emulate mouse with D-Pad. Make sure to set corresponding mapper values for this to work. Up, down, left and right keys are autorotated.
# forcetoolbar: Sometimes where's no space on screen to fit even a part of toolbar. This forces it to display. Also a key and a zone can be set for toggling.
# forcetransparent: Forced toolbar area, overlapping active screen part will be semitransparent.
# forcezone: X, Y, width and height of 'force toolbar display' tapzone. No spaces please. See also hand_force_tlbr setting in mapper.txt
# forceheight: Forced toolbar will have this height.
Is there a chance to get such configuration options for the Mac (and maybe Windows) version as well?
Yours,
McSquirrel
