brechtl wrote:i've also read about an other way of printing.
can you 'print' it to a .jpg file or pdf or something.
so that when I print in do […]
so that when I print in dosbox, it saves what i want to print on a file, and then that I open the file(without dosbox) and print it like that?
(sorry if my english isn't that good)
Ya you got it basically right. If you can print to a file in your app inside dosbox you should be able to send it to the printer once out of dosbox.
You'll need to print to a file using a compatible  printer driver from your app. for your printer.
For example, if you have a 600 dpi laserjet printer then you need to get your app, in dosbox to print to a file using a laserjet output. Some older hp laserjet and injet drivers such as a laserjet II should still print on a new hp laserjet with 600 dpi or higher. You may have to adjust the printer dpi settings first.
How to actually send the print file to the printer can be done several ways. I have a special windows passthru printer driver that will allow it but I haven't yet tested it in XP. Check the web or your  printer company site for ways to send print files to your specific printer.
