First post, by Simoon
hi there,
i bought Nordlandtrilogie "schicksalsklinge", an old dos game last week and i'm spending (wasting?) my time with getting it started. at the moment i've got 2 possibilities to play it:
- without dosbox, everything runs fine but midi sound (or whatever, i can hear the cd sound but nothing else) and the mouse doesn't move properly if it does at all
- with dosbox, it says the game needs a cd drive and it can't find any on my PC; no midi sound again...
so, it would be the best if someone just could tell me how i can get the mouse working under xp, that would be really great!
maybe i am too dumb for this stuff, but i am a great fan of this game and i neeeeeeeed it 😉
Simoon
Reply 2 of 6, by Simoon
hi there!
erm.... no. i use dosboxfrontend, a proram with a windows GUI, so that i don't have to do that shitty typing. how does this thing work/ how can i install it. i'd be thankful for a more detailed description how to do this!
nevertheless, thanks a lot for your help!
simoon
p.s.: i have got the problem that i cannot type "\" backslash, even the ascii code alt+92 doesn't work. that is why i have to use dosboxfro as GUI
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
Simoon wrote:
hi there! […]
hi there!
simoon
p.s.: i have got the problem that i cannot type "" backslash, even the ascii code alt+92 doesn't work. that is why i have to use dosboxfro as GUI
use "/" or type your commands in the [autoexec] of the dosbox configfile.
the mounting goes as follows
mount d d:\ -t cdrom
or mount d d:\ -t cdrom -ioctl
(presuming d:\ is your cdrom drive in windows)
Water flows down the stream
Reply 4 of 6, by Simoon
ok guys,
the cdrom problem is fixed now, although i don't know yet how to autostart the cdrom mount, do i have to type:
[autoexec]
# Lines in this section will be run at startup.
# mount d f:\ -t cdrom -ioctl
or how exactly?
i still haven't ANY sound in there, no cd sound and no midi... i wonder if we could get that fixed!
thanks, simoon
Reply 6 of 6, by eL_PuSHeR
As Snover "suggested", remove the # from the lines you want to execute. Otherwise, they will be treated as comments = ignored. It should look like something like this...
[autoexec]
