changing memsize
First post, by Fester77
wish for a feature :
being able to change memsize within dosbox like ems=true ems=false
if you got several games running under one conf it can be useful
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
aside from being able to use multiple configuration files, the next version of dosbox has support for restarting dosbox and thus using new settings that were not changable before.
Water flows down the stream
Reply 3 of 4, by Fester77
collector : that was a little insightful ... saw a some more parameters to play with but not anything that would do anything for this...
qbix : that sound interesting...
when i was checking z:\ for the internal command i thought config was the solution. but i atm it only writes conf files.
Im was hoping for it to be sort of like config -read (or somthing) name.conf and dosbox could restart itself with that conf instead of the default.
or maybe that IS what you´re getting at.
then i looked at loadfix but that only for the convetional mem.
else i hope that say i booted with 64 meg and loadfix could eat up 32 then wheneve the 64 was needed it could uneat those 32.
whould be a workaround but it whould make it "dynamic".
Reply 4 of 4, by Duffman
just change what you need in the dosbox.conf file
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
