First post, by An0nymous
Hello everyone.
First of all, let me apologize for yet another TESII Daggerfall post.
Secondly, I am using DOSBoz 0.74 on
Mac OSX 10.6.6
2 ghz dual core
4 gb ram
It is the patched downloaded version of Daggerfall on the Bethesa web site.
I'm able to run the game fine. The problem is that I get the following message sometimes when I save :
Daggerfall has encountered an internal error at 1000.
The error reported was: Failed internal check 14.
Exiting...
Now this only happens when I save. At first, I thought it was only when I exited a certain location or dialogue and didn't move around (save before and after quest, for example). But it seems to happen regardless now. As a matter of fact, I've tried it four times just now and the crash happened.
Indeed, i load my game in a fighter's guild, walk out, save; crash
Load game and go to another store, save; crash
Load game go outside and move around a little and save; crash
Load game, get a quest, save; crash.
I've read all the FAQs on how to mount the game, get it to run, and it has been running more or less well for a few days now. But it's to the point where I'm (ironically!) afraid to save by fear of it crashing...!
Any ideas?
Reply 1 of 4, by An0nymous
Here is the .conf on dosbox.
It seems to do it after I have a transaction with someone at the moment.
    dosbox.conf
    19.78 KiB
    353 downloads
Reply 2 of 4, by newrealization85
I have the exact same problem, running daggerfall downloaded straight from the website, installed and patched correct as far as I can tell. Running on mac as well. Have you figured anything out yet? Ive searched for this problem in other forums too and have found nothing.
Reply 3 of 4, by Miki Maus
Did you follow official instructions from Bethesda (which are apparently hard to find these days)?
Attached to this post for posterity.
    daggerfall_legal_and_installation.pdf
    21.49 KiB
    273 downloads
    Official instruction for installing Daggerfall in DOSBox from Bethesda.
Reply 4 of 4, by DosFreak
Also best ask on the Bethesda forums for better instructions than Bethesda's shitty ones instead of here.
Make your games work offline
