First post, by Markk
- Oldbie
I have a board that a friend gave me about a year ago, that I hadn't tried so much. It's written J-656C on it, so I guess the manufacturer might be Jetboard. It has Intel 430FX chipset, and it doesn't have dual voltage settings. There is only a jumper block that can make a selection between 3.3/3.45/3.6v. I had a P54 Pentium 133MHz on it, and I thought to replace it with a 166MHz MMX, just to see what happens. It starts ok, and it says Pentium-S 166MHz. Then I try a 200MHz one, and starts fine, the same way. So I thought to try also a 233MHz MMX, and setting the multiplier to 1.5x as the board indicates that the higher setting is 3x. It starts fine again, but it says again Pentium-S 200MHz. Then I thought to ruun speedsys, and I got that screen :
I'm a little amazed by that, as it seems to be working ok. My regular P233MMX has lower memory bandwidth(200MB/s) and was higher only when I had overclocked the CPU up to to 292MHz(250MB/s). Also the other board has a cpu score of 176,8, which is a little higher, but it also has 512kb level 2 cache memory, instead of 256kb that this board has.
Another thing that is weird, is the memory bandwidth of the vga card I used. It's a simple cirrus logic 5436 with 1MB ram I have just for testing boards. 25000+ kb/s is by far the highest of all the PCI cards I've got.... The Diamond 3D 2000(virge) with 4MB I have on my other pc, scores about 15500kb/s.
Then I run 3dbench 1.0c, and I get 160fps using the CL card. I replace the CL card with a S3 trio64V+ based one, with 2MB ram, and then it scored 165,2fps on 3dbench, whereas my other "good" board, with "official" mmx support, and the same cpu and the 4mb virge card scores 164,8fps.....
