First post, by retro games 100
- l33t
Recently, I bought a 486 POD83 Pentium overdrive CPU from Vogons user Ratfink. In the box was this very useful tool. It's 70mm long, and you can use it to lift up CPUs from their sockets. For the last 2.5 years I've been doing this with my finger nails, but not any longer!
Granted, some CPUs can be easily removed from their sockets and therefore don't require a tool, but sometimes the CPU pins are a little bent, and consequently the CPU can become a bit stuck in its socket. This tool excels when you are not dealing with Zif sockets, such as those found on mobos before the 486. Before acquiring this tool, I found removing 386 CPUs from their sockets to be quite awkward.
