First post, by emendelson
I know that Hercules Ramfont support is not bult into DOSBox, and I don't know if any games ever supported the Hercules Ramfont feature. (If no game supported it, then I understand that it will never be supported in DOSBox.) However, if anyone out there is experimenting with Ramfont support, and if you want someone to help with testing, I would be happy to do so.
I would like to be able to add this feature someday to a system I've put together (with the help of many people on this board) which uses a patched build to run WordPerfect for DOS:
http://www.columbia.edu/~em36/wpdos/wpdosbox64.html
Reply 1 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Haven't found technical docs on it yet
1+1=10
Reply 2 of 3, by emendelson
I can understand why that makes it difficult to support! Thanks for letting me know.
Annoying that there are no docs out there...
