How important is Tseng?
First post, by retro games 100
If you divide retro computing requirements in to 6 areas:
386, ISA
1) DOS
2) Win 3
486, ISA
3) DOS
4) Win 3
486, VLB
5) DOS
6) Win 3
Which areas would a Tseng video card be considered the best choice? Also, which areas would the choice of a Tseng video card be considered as "doesn't really matter - you can either use a Tseng, or you could pick something else - you won't notice all that much difference".
Reply 1 of 5, by elianda
There are good alternatives for each area. And Tseng cards are not the best choice for every application.
Youtube Channel
Reply 3 of 5, by elianda
Ofcourse you can choose this card because of its name. It is like some would like to have cards with a certain PCB color...
Reality is, if you got a decent card on 386 the CPU limits, maybe small differences work out on a fast ISA based 486 (40 MHz+).
For Win3, it might be a good choice to use a card with 2D acceleration. ET4K ISA does not have this.
For VLB there are also good alternatives, like cards with S3 chips.
Youtube Channel
Reply 4 of 5, by DBob
Option 1, is not a really good one. Lot of old games have different issues by Tseng cards.
I changed to a ISA Cirrus Logic card. The speed measured by landmark is the same (ISA bus limit), but the CL is more compatible...maybe even better picture on a tft...but this is a relative thing.
Reply 5 of 5, by sliderider
It's no secret I like Mach64 for ISA video cards but the Tseng 4000 based cards are good, too. If you're doing a separate VGA/3D combo using only PCI slots then a Tseng 6000/6100 as your VGA card is almost foolproof. If you can find an all in one VGA/3D card with a Tseng chipset doing the VGA part, so much the better but after a while ATi, nVidia and 3DFX became competent enough in their all in one solutions that you wouldn't want to use a Tseng card. I can't see using one with P5/P54 era hardware because later cards were still compatible with those motherboards and a few still had good backwards compatibility with older games.
