Pcchips M915i
First post, by luckybob
about a month ago I won one of these boards from a guy in belarus (russia). Well last week it FINALLY arrived, and I have good news and bad news.
good news, its a working board.
Bad news, even though the cache is real, the bios has disabled it.
attached is a benchmark I ran with my C5x86@100mhz. But the crazy thing is. the jumper settings are stupid easy on this board. its just one setting for any 3x multi chip. go figure right?
the bottom link has benchmark results, they seem kinda high considering there is no L2. is it just me or am i delusional?
Reply 1 of 16, by GXL750
I guess fake and real cache are incompatible with each other and a BIOS can only support one or the other.
Black PCI slots look nifty.
Reply 2 of 16, by luckybob
THATS WHAT MAKES IT SO SAD!!!
Reply 3 of 16, by Old Thrashbarg
How do you know the cache chips are real? Just because they're socketed doesn't mean they're not still fake...
But if they are indeed genuine, you might try a different BIOS version... it's supposedly flash upgradeable, and the latest one seems to be '9151108s".
Reply 4 of 16, by luckybob
the flash chip isnt socketed. and I dont have a "proper bios" meaning I'm not 100% sure its going to work. I'm willing to give it a try, I just have other projects on the front burner at the moment.
let me pull the sticker and see if its even flashable.
Reply 5 of 16, by Tetrium
Never seen that, but I have seen while ISA slots 😜
Shame it's a pc chips though.
Socketed BIOS is no good in this case, gives you pretty little options.
My retro rigs (old topic)
Report spammers here!
Reply 6 of 16, by PeteUK
PCI Slots?
VLB Slots surely.....
Reply 7 of 16, by Tetrium
PeteUK wrote:
PCI Slots?
No, take a look at this picture: download.php?id=9012
It's really black PCI slots on this board. Never seen that before, but I have seen a black s370 CPU socket, amongst a couple other different colors 😉
Reply 8 of 16, by DonutKing
Looks like PCI to me 😀
There are 2x VLB slots on the board as well, but I'd say the PCI slots are what tetrium's referring to.
486 boards that suport both PCI and VLB are pretty uncommon and quite versatile, its a shame they all seem to be made by pc chips 🙁
Reply 9 of 16, by Tetrium
They are uncommon, but many manufacturers made at least one, including ASUS 😉
PC-Chips == avoid
Reply 10 of 16, by luckybob
well teh board has gone from the back burner to one of the burners closer to the front. I looked up the bios strind ID and it is a PC chips M915I board. And the bios is from 1-1-1995. found a website that has a link for a bios dated 8-11-1995 that "adds support for cyrix 133 chips." http://www.rebios.net/biosdown/pcchips1.htm
But the link to the bios is borked. I emailed pc-chips driectly but havent heard back, and likely wont. Anyone happen to have this bios around? or a newer one even?
Reply 12 of 16, by Old Thrashbarg
This page has the BIOS ROM.
Some of those things have flash chips, some have EPROMs, and I'm not sure how you'd tell just by looking at it, since I believe the chip is just generically marked '915i' underneath the AMI label.
Reply 13 of 16, by luckybob
BLEH.
I'm wondering it I can get a generic chip, flash it, and re-solder it onto my board. I'd use a socket.
damnit, if I had a dollar for every time i've wanted my own bios flasher... I'd probably have about $20. 😜
oh, and under the sticker its marked "D" thats it.
Reply 14 of 16, by Old Thrashbarg
Well, flashing programs should at least be able to tell you whether or not it's a flash chip, so you could try it and just see if it recognizes it as flashable.
If it is an EPROM, then it'd most likely be a 27C010, and those can be directly swapped for a 27SF010 flash chip... so yeah, you'd still have some options available, it's just a question of how much work you feel like putting into a PCChips board.
Reply 15 of 16, by luckybob
its one of those things you know, I paid MONEY for this board. If swapping the bios chip lets me make use of that money then so be it. The board works surprisingly well for a no-cache board. 😜
Reply 16 of 16, by PeteUK
Tetrium wrote:
PeteUK wrote:
PCI Slots?
Meh.... Didn't see those... because they were black! 🤣
