First post, by sonicbrewtality
When i type the JAZZ prompt it says i need to run setup to configure my sound card. So i enter setup and select one of the cards, then i hit save and exit. Then i type JAZZ again and it just tells me to setup my sound card again. It says on the status window Warning: File Creation Failed for SOUNDCARD.INF. I'm running on Windows 7 64bit. Anybody know how to get this game working?
More info: I've never Used DOSbox before so maybe i've done something wrong. In the dosbox folder i made a folder called Programs, and inside that i made a folder called Games. I put all the files inside the games folder. Is that the right thing to do?
Reply 1 of 1, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Please, check the GUIDES section of the forum and read for awhile there.
