First post, by nemesis
I have recently proven myself as a competent overclocker when I succesfully clocked a 570MHz K6-2+ CPU at a mind blowing 556 MHZ!
I'm just trying to get it to stock speeds, and I'm following the instructions in the book and online as much as I can.
System so far is: FIC 503+ motherboard with BIOS v. JE4333
ACZ K6-2e+ CPU 570 MHz
128MB x2 PC133 RAM
I have the bus set at 95x6 right now.
Has anyone had any problems running these CPUs at their stock settings?
Btw, yes, the system does operate at the 556mhz, but I perfer it at it's intended speed.
EDIT: I set it to 112x5.5 and pushed the voltage to 2.1 from 2.0 and it's yielding 622mhz... so confused. 😖
Still, any suggestions on how to get this to work correctly will be greatly appreciated.
